Creo 8 FLEXlm/FLEXnet server compatibility.
Tomasz
3-Newcomer
Will Creo 8 run with LM version 11.14.1.2?
We are in the process of upgrading servers, to be able to run newest Flexnet, but will Creo 8 features work with older LM?
In all documents I can found it says 11.17.1.0 is recommended, but I cant found information will it run with 11.14.1.2
Mahesh_Sharma
22-Sapphire I
(To:Tomasz)
@Tomasz
Creo 8 is compatible with 11.16 or higher.
Reference aticle https://www.ptc.com/en/support/article/CS343197
5 REPLIES 5
KenFarley
(To:Tomasz)
If you're going to upgrade your servers, you'd probably be better off just going with the latest FlexLM. Our IT folk flagged my Creo 4.0 era license server as a security risk. I worried about compatibility with older versions of Creo and the latest license server, but was informed that things work fine.
Here's the discussion I had on here pertaining to FlexLM upgrades:
FlexLM Upgrade Discussion
Tomasz
3-Newcomer
(To:KenFarley)
Definitely will be upgrading for the newest one.
For now I don't have such option.
So the question is: will Creo 8 will work with LM 11.14.1.2 ?
Mahesh_Sharma
22-Sapphire I
(To:Tomasz)
@Tomasz
VladimirN
(To:Tomasz)
"FLEXlm/FLEXnet Server Version and Flexnet enabled applications Compatibility Matrix": https://www.ptc.com/en/support/article/CS154266
Tomasz
3-Newcomer
(To:VladimirN)
Thanks Vladimir,
I read this already 🙂
I might be wrong, but the header at the table says: FLEXlm/FLEXnet Server Version (Shipped)
It does not indicate clearly, that this is required for each Creo version.
