Dashboard loses connection in a browser
STEVEG
I am logged in to the Performance Advisor Dashboard on PTC's site.  Whenever I leave the browser alone for a short period of time it loses connection.  For instance: If I select to show one of the users it opens in another tab.  Then if I get called away, or just get on another task temporarily, and come back  then I see this in the user list.
This happens in both IE9 and Chrome 42.
I can do a refresh.  Sometimes the info comes back and sometimes it doesn't.  Most of the time in IE the screen goes gray on a refresh.  Then I have to close that tab and reopen it after a fresh of the previous tab.  Most of the time in IE I have to close all the tabs and open the Dashboard again to start all over.  Chrome seems to work better but it still loses connection.
In Chrome I will also get this error.
Any idea why this happens or if it can be fixed?
6 REPLIES 6
STEVEG
(To:STEVEG)
I guess nobody knows.
Hi Steve,
Sorry about my late reply, I was researching the situation a bit. This issue, where you see the red triangle when the browser goes idle, is know to our developers. They are working on a solution to the problem, and i will be sure to publish an article tracking the defect. Once the article is ready, I will post a link on this thread.
For now, i believe the workaround is to refresh the browser as you noted,
- Dan
Thank you Dan.  I am interested in what you find.
Dan,
Any update?
AndyHermanson
(To:STEVEG)
Dan this is the same issue it looks like that i emailed you about a day or so ago.
Here is the article tracking this issue: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS228017&lang=en_US
The development team is working to catch up on SPRs at the moment.
Thanks for your patience,
- Dan
