Hi, is there a list of drawing options, explanations & values in the help centre? In the help centre, under books, there are configuration options, but these are not the drawing options. It would be nice to see all the possible options in a format similar to the way the config options are laid out.
John
Hi John - I have found something for you ![]()
http://www.beyondmech.com/pro-e/cad-topic-31.html
... it is not full list, but ... try to check it.
Thanks Vladimir,
you are right, by no means a full list, but one or two i have not seen before.
Regards
john
note: I think that it is not necessary looking for list of configuration options and description - because if you open any drawing >> dtl file - system contains full list and description too
Vladimir,
yes i know this, but is that all the options listed there? Are there any not listed? that only become visible if you use the find function & add/change a value. The reason i ask, is because yesterday i became aware of a config option i never knew existed (see the post about pdf output), that cured a problem that has plagued me for years. How many more such config options exist.
Regards
John
John,
I never found some list of dtl options - maybe some guys from PTC can help us - we can wait for it ![]()
I retire in 2035, would be nice to get it before then ![]()
John
