EFX_LIBRARY_PATH
BenLoosli
EFX_LIBRARY_PATH
I added this line to my config.pro for Creo 9.0.5.0:
EFX_LIBRARY_PATH X:\OR\Engineering\Systems\PTC_Settings\afx\
It gives an error message when I look at my active configuration that it is an invalid setting.
I did copy the <loadpoint> Common Files/afx folder to  X:\OR\Engineering\Systems\PTC_Settings
I got the information from a 2018 thread, so I wonder if the settings have changed since then?
2 REPLIES 2
it seems to me that EFX_LIBRARY_PATH option is not valid one anymore.
I hope @SamuelBrantner can help you.
Martin Hanák
Hi @BenLoosli ,
that was never a config.pro option actually.
Please check this video that will give you the correct workflow to customize AFX:
https://youtu.be/-iLYU-YT8e4?si=-BJWN_g08V9BVOhL&t=430
I hope this helps
Samuel Brantner
B&W Software GmbH
