The last 3 days I have been having a error with the software and it causes that the software shuts off. Attached you will find the message sent by the software before it closes.
I would like to get a solucion for this issue, Do you think that I should reinstall the software?
Thanks.
Andres,
I think you could have more help if this question will be moved in Creo section.
I'll ask Toby to do it for you.
Good day Andres -
I have moved this to Creo - thanks for the help Marco Tosin
Andres,
Error reported in post is generic message for premature exits of Pro/ENGINEER and Creo. If this can reproduce, you can submit a case to PTC technical support for further investigation.
