File saving problem
jsarkar
File saving problem
Now-a-days I am facing a new problem in creo 2, when I am saving any file from the menu bar file> save> then rapidly pressing mid button, its not saving at all. By clicking ok button its perfectly saving. As far as I can remember i always used to save by rapidly pressing mid button after file>save in previous version. Have anyone came across such kind of situation?
6 REPLIES 6
rohit_rajan
(To:jsarkar)
it is still getting saved by pressing middle button...i am using CREO 2.0 M010. hope your mouse is not an issue?
It should make no difference whether you click the middle mouse button rapidly or slowly - MMB for "Done" or "OK" should work for most functions in Pro/E, including File->Save and File->Open.
Sometimes I try to use this for File->Open in other applications - then it doesn't work!
jsarkar
(To:jsarkar)
My mouse does not have any issue, however some intralink options are set. I suspect may be because of those options. Seems like i need to investigate little more. Anyway thanks for reply.
Dale_Rosema
(To:jsarkar)
Sorry about that. I'm an old school. Alt-F, S, slap the space bar with your thumb guy - - give that a try. But I know that we each have our ways.
Gee
(To:jsarkar)
I use the mid mouse button in many places instaed of clicking done. Did you check whether you are getting this problem only when you save the model or in all other operations..
Normally people use a single letter mapkey to rapidly save the files.
jsarkar
(To:Gee)
it happens only in case of saving
