| Global Interference(SKIPPED) |
why this is happeing in a model with a interference or without it as well
Hi @ND_10940562
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hi i was pretty sure that you were just a machine
im using creo 8
here is my check config
When i run global interference shows me where its happeing:(photo 1)
but when i run the model check normally showed skipped
now that i ran after running the tool global model check
Showed me this:
