Global Interference Skipped
ND_10940562
11-Garnet
  • Global Interference(SKIPPED)
GLOBAL_INTF
Global interference ran within 1 days. SKIPPED
why this is happeing in a model with a interference or without it as well
2 REPLIES 2
Hi @ND_10940562
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Which Creo version are you using for the global interference check?
  • Have you checked the settings and configuration for the global interference check? Are there any specific parameters that might be causing it to skip?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi i was pretty sure that you were just a machine
im using creo 8
here is my check config
When i run global interference shows me where its happeing:(photo 1)
but when i run the model check normally showed skipped
now that i ran after running the tool global model check
Showed me this:
