Hi Bob,
Can you send me the data where you are seeing this? I'd like to run it by development.
Generally, if an attached preview is shown for a feature, the feature should be able to be created properly. However, in order to generate the attached preview as quickly as possible, we do take some shortcuts in the generation code. This can occasionally result in a successful attached preview, but the feature fails when it is fully generated.
That said, the more we learn about these kinds of cases the better we can handle them, so I’d appreciate a chance to see the data.
Thanks!
Don Breda
In Reply to Bob Schwerdlin:
I REALLY LOVE when CREO or WF shows you a round that you are about to put into your model. It highlights the round feature and shows you just how it will look once you hit the green check button. Great! So you press the green check button and CREO takes the round feature away and say, “Cannot create round feature”. It’s PTC’s way of saying, “Just messin’ with you, sorry”.
I love that one.
Happy Friday.
Bob
