Trouble converting .prt file into .stl format...
- April 11, 2015
- 3 replies
- 3910 views
Hello everyone, I am working on a solid model here and i want a 3D print of it and the printer requires .stl file format, the problem is my solid model which is a .prt file is not saving as .stl file format. there is no option available in 'save as' drop down menu where i can select the file to be saved as .stl file format. My .prt file is a complete solid not a surface. Anyone here knows where is the problem? i have attached the file i want to convert
I am using CREO Parametric 1.0.
my bad sorry for bothering you guys...
