How do you change color for solid edges in wireframe
pimm
I would like to see all the edges in solid geometry but I see that the color for edges when in wireframe is white which is a terrible contrast for a white background.
I've searched config options under display.  I've also searched all the other areas of the Options setup.
This must be easily done, but I have no clue where to find this.
DonSenchuk
(To:pimm)
Ah.
My wireframe follows the color the model is set to. Green solid equals green wireframe.
I don't know off hand if there is a setting for this.
6 REPLIES 6
DonSenchuk
(To:pimm)
File > Options > System Colors > 'Shaded Edge' at the bottom of the right hand column.
pimm
(To:DonSenchuk)
Don,
I do have the Shaded Edge as a reasonable color but when you go into the Wireframe display style it is evident that the edges for all solid geometry are white.
DonSenchuk
(To:pimm)
Ah.
pimm
(To:DonSenchuk)
This is my mistake.  I am using a white colored solid.  If I use a different color the wireframe becomes that color.
I would prefer the edges be black, but at least I know I can control what I see.
saarj28
3-Newcomer
(To:pimm)
Though, the thread says the question has been resolved but I feel we should explain in detail.
I faced the similar issue recently.  I selected the following steps and it worked 🙂
>> Go to File>Option>Entity Display>Un-check "show colors assigned to model surface". See the snapshot attached.
nkamal
8-Gravel
(To:saarj28)
Hello guys,
I know it's too late, but I just noticed that turning off "Anti-Aliasing" also gives a good edge display in "No Hidden" viewing mode.
Cheers
