How to Modify the parameter
SK_10671131
Hello Team,
please find the below image, How to edit the given locked parameter.
BenLoosli
(To:SK_10671131)
First question is why do you need to unlock it?
Your system admin has enabled MC for a reason and the locked MC parameters are created by the MC software.
If you disable MC, restart Creo, then maybe it will allow you to delete the MC parameters.
As a system admin, I know I cannot delete them in a normal session of Creo and I have not tried with MC disabled.
