Hi everyone, I have encountered a problem during instalation of Creo 3 M70.
I have available licence from University, everything is fine, but in the instalation itself it gets stuck and reports a problem that in english can be translated as "Overlapping IO operations being processed." Or something like that.
I have turned off my better GPU, now Im using Intel HD3000, Windows 10 x64 but I dont think that is the issue. Running as admin is not helpful either. Thank You for any help provided Im a bit desperate.
I met similar problem. It was caused by path to directory, where unzipped installation media was located.
MH
I have used the same procedure as you, sir.
Anyway, I bought an energy drink and tried all possible solutions and got to success.
For everybody with similar issue:
At first I manually installed \install\addon\creoagent_32_64.msi
then I launched the installing setup again and it installed properly.
Im not discussing that anymore, Im just happy I solved it.
Thank You for those hints anyway and have a good day.
