The sketches are still there, though they have their feature number removed and are "consumed" into the Intersect feature (have to click on the '+' symbol to see them in the MT). But they are locked up. I can't do anything with them. If I do what Brent suggests, I can have multiple copies of the same sketch, but I have to do that Jeff
In Reply to Doug Schaefer:
The sketches should still exist in the tree where they were and be available for other uses. They will just be hidden. It’s possible your model tree is set not to show them. Go to Settings > Tree Filters and make sure ‘Used Sketch’ isn’t cleared:
[cid:image001.png@01CE19C0.1091F820]
The plot thickens..... When I do it, it doesn't matter whether I select Geometry or Features, I get the same (undesired) result. The sketches are locked up in the new intersect feature and I can't get them out. I'm convinced now it is a config setting, I just don't know which one.
BTW, yes, when you edit one version of the sketch, it updates all of the versions as they are all the same sketch.
I have a workaround solution for this issue, but it ain't pretty: You have to c
Convoluted? yes, but then again we are talking about Pro here.
In Reply to Nathan Rollins:
This must be a config setting or something. I may not be able to offer any
real help, but coincidentally, today I am in WF4 and I made a 3D curve using
intersecting curve with two sketches. I can confirm what Doug says was true
for me. The original sketches remained - hidden (grayed) - but fully there
and modifiable. After deleting the intersection, the originals were still
there. I am 95% sure I selected the feature to create the intersection -
not the geometry.
Woah.
This just in.
I just tried to create a curve intersection by selecting the geometry - as
Brent suggested - and I got the behavior that Jeff is seeing. Eff - with a
capital E.
What are they thinking? The original sketches get absorbed into the feature
and cannot be extracted. They disappear from the tree. They can be edited
with a RMB in the tree. But, get this - any other children of that original
sketch receive an absorbed copy of the curve - I am not sure if the
children's copies are linked. I don't think I care to learn either. Maybe
someone out there can explain WHY this is useful? I promise to listen and
consider. Seems pretty stupid to me.
Jeff, you need to create your intersection curve by selecting the feature -
NOT the geometry. This will solve your issue - methinks.
Screen looks like this when selecting the FEATURE of the curve (red):
Now that Nate is seeing both behaviors, I'm totally stumped. I was about to suggest it might be different builds of WF that do this (I'm on WF4 M190) but now I'm not so sure.
I'm going bald at the same rate as Nate about now.....
Nate - sorry to have messed up your work yesterday.
Jeff
