Issue with solid line through a hole feature i drawing mode
�B_10498858
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
Problem with solid center line showing up in a drawing view. Its a offset section with a sketch where there is two lines in 90 degree The section is showed by a full unfold, partial view.
Not sure if this is suppose to look like this or if its a bug or if there is any detail settings to hide the solid line that goes through the hole feature?
6 REPLIES 6
please attach some pictures. If it is possible pack your files into zip file and upload this zip file.
Martin Hanák
Hi, here is 2 different drawing views with same issue. There is a solid line that i would like to have removed.
there is drawing option create_area_unfold_segmented. It is set to yes by default and you can switch it to no.
Unfortunately it only affects Area section views, not Total section views.
Fortunately there is also drawing option show_total_unfold_seam. It is set to yes by default and you can switch it to no.
It affects Total section views.
Martin Hanák
Hi!
This works when you do not use partial view. Its when you also show the view as a partial that the solid line gets visible.
Best Regards
I can't do anything about it.
Martin Hanák
Thanks for your help anyway.
