Issue with text_height in Drawing Detail Files
KS_13238586
7-Bedrock
Hi Everyone
I am using two separate detail files for two different config options:
drawing_setup_file
format_setup_file
When I create a new drawing, I get the following error in the Message Log:
Error(s) in C:\Program Files\PTC\Creo 11.0\custom\ISO-prt-asm.dtl. See datafile.ers.
 In datafile_error.txt, the error is:
ERROR - C:\Program Files\PTC\Creo 11.0\custom\ISO-prt-asm.dtl, line 2: Invalid value 'CALCULATED' for keyword 'text_height'.
Note:
Both detail files contain the same config option text_height.
In ISO-prt-asm.dtl (used as drawing_setup_file), the entry is:
text_height CALCULATED (Causing an error)
In ISO-frm-prt-asm.dtl (used as format_setup_file), the entry is:
text_height 3.5 (Not causing an error)
OBSERVATION:
If I changed the value of "text_height" from 3.5 to "CALCULATED", ISO-frm-prt-asm.dtl file is also making an same error I mentioned above.
Software: Creo Parametric 11
Can Someone help me on this?
Thanks.
2 REPLIES 2
Hi @KS_13238586
Thank you for your question.
Anurag
Van_AG
(To:KS_13238586)
text_height calculated works only for model dtl-file
used for MBD for example
for formats/drawings dtl text_height calculated is incorrect
