mapkey to run system window in creo12
  • January 11, 2026
  • 96 views
how can i run utility system window basically command prompt in creo 12 with mapkey its not happening with this latest version
Can you provide an example of the mapkey you are trying to run?
Specifically what version of Creo 12 are you on?
