The message you are trying to access is permanently deleted.
hello.
my support has expired and I can not use.
now I have a problem when I should start my Creo 2 with this error Notice:
License request failed for feature
would you please explain how I should do?
Reza,
locate std.out file in your working directory, open it and copy its contents into your next Reply.
Martin Hanak
Requesting PROE_FoundationAdv ...
7788@reza-w8: (-97) The desired vendor daemon is down.
Reza,
is reza-w8 the only one computer ? This means ... is reza-w8 used as license server and also as Creo workstation ?
Or is reza-w8 used as license server and second computer as Creo workstation ?
In this second variant, license server can be blocked by Windows Firewall. You can turn it off and try starting Creo.
Martin Hanak
Hello Martin.
excuse the late response.
yes, it is only this computer as the license used by.
greetings
Reza
Reza,
Please provide complete error message information, better a snapshot.
Browse to system services (Start > Type Services) and look for lmadmin_ptc or flexlm server for PTC. You may have one out of those, select that Right Click and Start or Restart.
> Start Creo.
If this fails:
Open PTC License Server Tools > Config services > View log > and check for any error in last few lines. If any please add to reply in the post.
hello.
I have Windows 8 on my PC. can you explain a bit more how I do this?
greetings
Reza
Is it Windows 8 or 8.1?
Windows 8.1
Right click on Windows icon (bottom left corner) > Run > Type services > In services look for lmadmin_ptc or flexlm server for PTC, slect the service and restart. Try launching Creo.
If above step fails, check which version of license manager is installed from Program & Feature list, it can be PTC Flexnet admin license server or PTC License server.
If it is PTC Flexnet admin license server, browse to C:\Program files\PTC\Flexnet Admin License Server\logs and open ptc_d.log in notepad and check for any possible error information.
If it is PTC License server, browse to C:\Program files\Flexnet\licensing and open ptclmgrd.log in notepad and check for any possible error information.
Hello.
Unfortunately, after so much trouble so I installed all of the PTC-related programs from my computer with the hope to reinstall them.
but now I see that I can not access the FLEXnet License Services.
do you have any tips on where I can download it?
on the PTS website is not because I do not have a support contract.
Greetings
Reza
Reza,
contact the VAR who sold you PTC products.
Martin Hank
