License request failed for feature
rtaleb
hello.
my support has expired and I can not use.
now I have a problem when I should start my Creo 2 with this error Notice:
would you please explain how I should do?
13 REPLIES 13
Reza,
locate std.out file in your working directory, open it and copy its contents into your next Reply.
Martin Hanak
Martin Hanák
rtaleb
(To:MartinHanak)
Requesting PROE_FoundationAdv ...
7788@reza-w8: (-97) The desired vendor daemon is down.
Reza,
is reza-w8 the only one computer ? This means ... is reza-w8 used as license server and also as Creo workstation ?
Or is reza-w8 used as license server and second computer as Creo workstation ?
In this second variant, license server can be blocked by Windows Firewall. You can turn it off and try starting Creo.
Martin Hanak
Martin Hanák
rtaleb
(To:MartinHanak)
Hello Martin.
excuse the late response.
yes, it is only this computer as the license used by.
greetings
Reza
Mahesh_Sharma
22-Sapphire I
(To:rtaleb)
Reza,
Please provide complete error message information, better a snapshot.
rtaleb
(To:Mahesh_Sharma)
Mahesh_Sharma
22-Sapphire I
(To:rtaleb)
Browse to system services (Start > Type Services) and look for lmadmin_ptc or flexlm server for PTC. You may have one out of those, select that Right Click and Start or Restart.
> Start Creo.
If this fails:
Open PTC License Server Tools > Config services > View log > and check for any error in last few lines. If any please add to reply in the post.
rtaleb
(To:Mahesh_Sharma)
hello.
I have Windows 8 on my PC. can you explain a bit more how I do this?
greetings
Reza
Mahesh_Sharma
22-Sapphire I
(To:rtaleb)
Is it Windows 8 or 8.1?
rtaleb
(To:Mahesh_Sharma)
Windows 8.1
Mahesh_Sharma
22-Sapphire I
(To:rtaleb)
Right click on Windows icon (bottom left corner) > Run > Type services > In services look for lmadmin_ptc or flexlm server for PTC, slect the service and restart. Try launching Creo.
If above step fails, check which version of license manager is installed from Program & Feature list, it can be PTC Flexnet admin license server or PTC License server.
If it is PTC Flexnet admin license server, browse to C:\Program files\PTC\Flexnet Admin License Server\logs and open ptc_d.log in notepad and check for any possible error information.
If it is PTC License server, browse to C:\Program files\Flexnet\licensing and open ptclmgrd.log in notepad and check for any possible error information.
rtaleb
(To:Mahesh_Sharma)
Hello.
Unfortunately, after so much trouble so I installed all of the PTC-related programs from my computer with the hope to reinstall them.
but now I see that I can not access the FLEXnet License Services.
do you have any tips on where I can download it?
on the PTS website is not because I do not have a support contract.
Greetings
Reza
Reza,
contact the VAR who sold you PTC products.
Martin Hank
Martin Hanák
