Hello community,
I'm running a very old MELS on a VM (Win7, 32bit) for an also old version of ME10 8.7
The VM runs only for the MELS and the software is getting older and older and I want to install it directly on my server (Win2012R2, 64bit)
Sadly the old setup cannot run under this new OS.
Has anyone an idea where I can find a MELS-setup which can run under 64bit?
I searched, but found nothing... 😞
regards
The "Link" results in a Website where I'm not authorized to download anything.
I read the "Topic" but there is also no solution for a download. But there was a friendly community member who sends the setup to the thread owner.
@TS_2331168 wrote:
Hello community,
regards
I do not know the solution ... I am curious, only.
Does this mean that when you double-click setup.exe (or something like that) then nothing happens ?
Did you start setup.exe from command prompt ?
Note: Maybe installer is 16-bit and therefore it does not run on 64-bit OS.
Question: Can you upload installer ?
When I double click setup.exe the OS says that this version cannot run under 64bit.
Yes, maybe this is a old 16bit file.
Why do you want the setup file?
I asked for setup file to test it in my Windows 10 64-bit for you. Otherwise I don't need it.
I found simple AutoIt script https://www.autoitscript.com/autoit3/docs/libfunctions/_WinAPI_GetBinaryType.htm which enables user to recognize the type of exe file.
I also tested it with compatibility mode in Win10 64bit, Server 2012R2 -always with no success. I think the software is really too old. I guess its from 1998 😕
my last tip ...
1.]
In Windows 7 check MELS processes whether they are 16-bit or 32-bit.
2.]
If they are 32-bit then copy MELS installation directory to Windows 64-bit and create MELS service manually.
Sorry, I'm not able to run this script and find it out right now. But I'm quiet sure, that this is a 16bit setup file.
I think the solution would be a new setup file with 64 compatibility.
