: Microsoft Surface Pro 3
BrianKrieger
And just to confirm here, the config.pro option that was included in Gary’s link got our embedded graphics machines up and going on M100. Haven’t tried M120.
enable_opengl_fbo no
When we had run into this issue prior, we just rolled the users back to m070 (the last build that worked). We are on M100 and the integrated graphics computers appear to work with the mentioned config setting. According to the CS, though, CP2 should auto-detect the old intel drivers causing the problem and switch to fbo-->no, so maybe M120 still needs it specifically set (i.e. it isn’t auto detecting appropriately).
BK
For my SP3, "enable_opengl_fbo no" did not make a difference.
I did not try the following, which were also offered:
· enable_opengl_vbo no
· enable_opengl_shader no
Walt Weiss
I found it ironic that as a discussion on how CP2 doesn’t work on a Pro 3 is ensuing, PTC posted the video that CP2 was used to design the next gen surface pro. I guess the caption should be CP2 used to design next gen tablet that won’t run CP2……well…… ☺
Though it sounds like an intel/ptc issue as opposed to Microsoft/ptc (just to split a few hairs).
BK
