Model Tree not updating
BrianKrieger
We recently upgraded to PDMLink 10 and Pro/E m140. We have a transient issue where the model tree doesn’t update when new components are added. If the user activates the window the components show up. We’re trying to track down if there’s some config setting, but…….?
Anyone else see this (even if in the past as it does appear this kind of thing has surfaced before) or have a “hey, do this” (other than activate the window)?
Thanks, gurus!
Brian Krieger
Petebilt Motors
9 REPLIES 9
Thanks, Charlie!
I’m disappointed that I couldn’t find anything on this (I thought my searches were thorough……sigh).
FYI, m150 is due August 3rd.
Thanks for the quick response!
Brian Krieger
Peterbilt Motors
PS: Sorry to my company and to all Peterbilt (with an “r”) fans for my lack of spell checking J.
BenLoosli
(To:BrianKrieger)
You have incompatible versions!!!
Windchill 10 requires WF4m190 minimum.
Depending on your build of WC10, you may require a higher build of WF4.
I am doing an upgrade to WC10m030 and it requires WF4m210.
Thank you,
Ben H. Loosli
USEC, INC.
BenLoosli
(To:BrianKrieger)
WF5m150 was released early! It is available today.
Thank you,
Ben H. Loosli
USEC, INC.
Had a quick look at the update advisor this morning but didn’t find anything related to this issue...
Anyone have a reference to this bug?
Kind regards,
Frederic
I just tried WF5 M150, on my reproducible data set, and I can confirm that the model tree now updates properly. At least for me and this particular data set...
> Thank you,
> Ben H. Loosli
> USEC, INC.
> *From:*Brian Krieger [mailto:-]
> *Sent:* Wednesday, July 25, 2012 9:28 AM
> *To:* -
> *Subject:* [proecad] - RE: Model Tree not updating
> Thanks, Charlie!
> FYI, m150 is due August 3^rd .
> Brian Krieger
> Peterbilt Motors
> *From:*Price, Charles [mailto:-] <">mailtoSmiley Embarassed
> *Sent:* Wednesday, July 25, 2012 8:10 AM
> *To:* Brian Krieger
> *Subject:* RE: Model Tree not updating
> Fixed in M150 – (known problem)
> Charlie Price
> Principal Engineering Specialist
> Diebold, Incorporated
> 330 490-4552
> - <">mailto:->
> *From:*Brian Krieger [mailto:-] <">mailtoSmiley Embarassed
> *Sent:* Wednesday, July 25, 2012 8:52 AM
> *To:* - <">mailtoSmiley Tongue->
> *Subject:* [proecad] - Model Tree not updating
> Thanks, gurus!
> Brian Krieger
> Petebilt Motors
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
sbugros
6-Contributor
(To:BrianKrieger)
We are using Creo Elements Pro 5 M160, one of our users has this problem whenever he adds a feature or a part the model tree does not update unless he clicks on Window > Activate.
Has anybody ever seen this before?
Thanks in advance.
Steve
Steven Bugros
Brookhaven National Laboratory
Collider-Accelerator Department
Building 911 B
35 Lawrence Drive
Upton, N.Y. 11973
631-344-3259
bugros@bnl.gov
We have the same problem here, it's a bug.
Brian Yoder
P: 651.633.4200 x2058 F: 651.633.5486
E: brian.yoder@donatelle.net<">mailto:brian.yoder@donatelle.net>
StephenW
(To:BrianKrieger)
We have the issue on M140 but when I upgraded to M150, the problem was fixed. I didn't even know M160 was available till now. I guess they used M140 as the base.
Steve
sbugros
6-Contributor
(To:BrianKrieger)
Steve, Brian... you are right. My guy was using M140. I updated him to m160 and life is good again.
Steve
