ModelCHECK is telling me that I have views that do not have scale assigned, but my views DO have Default scale assigned. Is VIEW_SCALE working as intended here? I would think that Default scale would count as an assigned scale.
Response from PTC Support.
"ModelCHECK Check VIEW_SCALE is designed to report views in drawings which do not have assigned scale. However, there is no exclusion for views which have default drawing scale. When VIEW_SCALE is set to error/warning and dawing views have scale assigned drawing scale it will report error/warning and this is per current limitations of ModelCHECK."
please ask PTC Support the same question.
Case 16592953 has been opened.
