ModelCheck - Regen Errors/Warnings
MikeLockwood
22-Sapphire I
I've got ModelCheck pretty well dialed in now (and have good test models and drawings that violate each check for demo / discussion / training) - but continue to refine many checks, especially those that don't seem to work at first pass.
Please see attached if interested (labeled with pending tech support case number).  It shows a feature which will not regenerate, and the specific message in the message log, and the MC configuration which should find it - but MC reports no Regen Errors.  Note that MC was run in Interactive Regenerate mode for this.
thanks in advance for insight on this particular check
Mike,
Try adding
"W: Feature regeneration failed." in mc_regen.mcr and add REGEN_ERRS and REGEN_WRNS to error. And try ModelCHECK Regenerate
