ModelCheck conditional lifecycle AND units determin configs to use?
DavidFrancis
I am attempting to set up mutliple config files depending on lifecycle / release state.
What I cannot figure out is how to make a boolen work in the condition config file as in the following:
(These are the states and parameters PTC documentation suggest, however, I want to add the AND statement for IN vs. MM)
I have tried & && and as you see AND.......
# OVERRIDE CHECKS
IF ( NOCHECK ) NOCHECK
#Lifecycle States INCH
IF ( PTC_WM_LIFECYCLE EQ Basic ) AND ( MODEL_UNIT EQ INCH )
config=(check/basic_check.mch)(start/basic_start.mcs)(constant/inch.mcn)(status/basic_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Release) AND ( MODEL_UNIT EQ INCH )
config=(check/release_check.mch)(start/release_start.mcs)(constant/inch.mcn)(status/release_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Approval) AND ( MODEL_UNIT EQ INCH )
config=(check/approval_check.mch)(start/approval_start.mcs)(constant/inch.mcn)(status/approval_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Review ) AND ( MODEL_UNIT EQ INCH )
config=(check/review_check.mch)(start/review_start.mcs)(constant/inch.mcn)(status/review_status.mcq)
#Lifecycle States MM
IF ( PTC_WM_LIFECYCLE EQ Basic) AND ( MODEL_UNIT EQ MM )
config=(check/basic_check.mch)(start/basic_start.mcs)(constant/mm.mcn)(status/basic_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Release) AND ( MODEL_UNIT EQ MM )
config=(check/release_check.mch)(start/release_start.mcs)(constant/mm.mcn)(status/release_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Approval) AND ( MODEL_UNIT EQ MM )
config=(check/approval_check.mch)(start/approval_start.mcs)(constant/mm.mcn)(status/approval_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Review ) AND ( MODEL_UNIT EQ MM )
config=(check/review_check.mch)(start/review_start.mcs)(constant/mm.mcn)(status/review_status.mcq)
ELSE set the fallback (CADDocument OIR - LifeCycle Name at
Container level)
Any insight is welcome... : )
David T. Francis
llie
(To:DavidFrancis)
David,
Your statements look good in the way that you call out the different
lifecycle states as noted from PTC.
Are you setting up Gatekeeper? If so, I would look at the IBA's that you
setup.
We had to change the names different from the documentation.
Lance Lie
Sr Computer System Technologist II
310.334.1934 office
310.426.4968 cell
310-334.3078 fax
