Paul,
Could it be that you're running a 32-bit benchmark on a 64-bit system? Is there a 64-bit version of the benchmark that you can run?
I've noticed that 64-bit OS and drivers are not as mature or well maintained as the 32-bit counterparts. My Dell Precision M4400 running Windows XP Pro 64-bit has been quite unstable compared to my prior Dell Precision M65 running Windows XP Pro 32-bit. I believe that the only reason to go with 64-bit is to break through the 4GB RAM barrier if you have large/heavy assemblies open. Otherwise, you're probably better of going with a 32-bit system if possible for better support and compatibility.
Willy Chung
