Old school sweep in CREO 2.0???
bokm9606
Ok,
Trying to figure out if you can do an old school simple sweep in CREO 2.0? In WF5.0 it would be:
Pull down: Insert
Sweep -> flyout
(surface, cut or solid)
I loved this feature in the fact that it could "Add INN Faces" on closed trajectories. I used/use this functionality all the time.
Has this been removed from CREO 2.0? If so, WHY???!!!
Is there a way to access this feature via a config setting??
Please advise,
Pete
Old School? Try this mapkey. It pulls up the old Menu Manager and you can select the sweep option from the list.
mapkey cp #FEATURE;#CREATE;#SOLID;#PROTRUSION;
Patrick
mlocascio
(To:bokm9606)
In Creo Par 2 it is under SWEEP..
Awesome tip Patrick! I will give this a try
> Patrick
> *From:* pete bokma [
> Please advise,
> Pete
DeanLong
(To:bokm9606)
Ha....had laugh at the "Old School" sweep statement. That thing has not changed in fifteen years! 🐵
no need to change a "classic" haha
On Mon, Jun 30, 2014 at 9:26 AM, Dean Long <->
> changed in fifteen years! Smiley Surprised)
