Ok,
Trying to figure out if you can do an old school simple sweep in CREO 2.0? In WF5.0 it would be:
Pull down: Insert
Sweep -> flyout
(surface, cut or solid)
I loved this feature in the fact that it could "Add INN Faces" on closed trajectories. I used/use this functionality all the time.
Has this been removed from CREO 2.0? If so, WHY???!!!
Is there a way to access this feature via a config setting??
Please advise,
Pete
Ha....had laugh at the "Old School" sweep statement. That thing has not changed in fifteen years! 🐵
