Hi my Macbook M1 Windows 11 ARM Ptc creo 7.0 when installed, Creo will not run - nothing happes.
i'm sure win11 in my desktop runnung creo7.0 and 8.0. but not my mac m1 chip.
Discussion - "Creo on mac": https://community.ptc.com/t5/System-Administration/Creo-on-mac/td-p/36189
Macbook M1 processor is not supported hardware platform. You have to use Intel/AMD processor.
I have successfully installed Creo 3 M190 X32 on my MacBook Pro M1. All modules work perfectly, rather its up and running faster than my other Windows 10 Laptop. Problem is X64 versions of Creo. Unfortunately Creo 3 is the last version that is available in 32bit.
Cool! Did you run it in Parallels or something else?
Parallel Desktop
have you tried installing/running newer versions of Creo?
Ian
