Hi Guys,
Can somebody tell me how to get rid of this problem:
as you could see on the picture above the lines are in teeth form and this is only on one pc in our office. can somebody advice me how to make these lines more smooth.
10x in advance and have a nice day !
Hi Radoslav,
Do all the PC's use the same config.pro settings?
You could try increasing the Anti-Aliasing under Entity Display Settings.
Off On x16
Miles
Radoslav,
look for differences between your PCs...
Martin Hanak
Unfortunately there are 3 more pcs exactly the same (both hardwear and softwear) and i have this problem with only one of them
Radoslav,
my suggestions:
Martin Hanak
Is your monitor/graphic resolution or display settings the same between the pc's?
(windows 7: RMB desktop > screen resolution)
Ron
yes it is everything seems to be the same and thats why i am so confused obout the difference in views
Did you try a higher shade quality in the options?
yes i did but there is no difference
Hi Radoslav,
Off On x16
Miles
HI Miles could you kindly point me to this Anti-Aliasing option cause i cant find it
10x in advance !
Radoslav
In Creo
File -> Options
Then Entity Display.
i am working on proe wf4 but i made this settings from nvidia tool and now it work perfect thanks a lot !
