I am using Creo Parametric Release 10.0 and DatecodeNA
Creo Simulation Live include the fluid simulation study. I tried with all the versions.(Advance premium version).
Hi GG_10585693,
I hope you have received a new license file with appropriate license (CREO_SIMULATION_LIVE_FLUID (385) or CREO_SIMLIVECFD_SET (10138)), if so, you need to update license manager (CS77700) and reconfigure Creo Parametric (CS386152) to add new license features.
I hope this will help.
Thanks.
open your license file in Notepad and check whether it contains the appropriate license code.
Hi @GG_10585693 ,
As Martin suggetsed, check the license file for license. Also, share an image of error, if any, for more clerification.
Thanks.
I already checked the license file but the feature CREO_SIMULATION_LIVE_FLUID (385) or CREO_SIMLIVECFD_SET (10138) are not there.
What can I do ?
Hi GG_10585693,
Thanks.
