3-Newcomer
May 4, 2023
Problems with simulation live, fluid simulation study is not working
  • May 4, 2023
  • 2 replies
  • 1550 views
I am using Creo Parametric Release 10.0 and DatecodeNA
Creo Simulation Live include the fluid simulation study. I tried with all the versions.(Advance premium version).
Best answer by Mahesh_Sharma
Hi GG_10585693,
I hope you have received a new license file with appropriate license (CREO_SIMULATION_LIVE_FLUID (385) or CREO_SIMLIVECFD_SET (10138)), if so, you need to update license manager (CS77700) and reconfigure Creo Parametric (CS386152) to add new license features.
I hope this will help.
Thanks.
open your license file in Notepad and check whether it contains the appropriate license code.
Mahesh_Sharma
22-Sapphire I
May 5, 2023
Hi @GG_10585693 ,
As Martin suggetsed, check the license file for license. Also, share an image of error, if any, for more clerification.
Thanks.
3-Newcomer
May 5, 2023
I already checked the license file but the feature CREO_SIMULATION_LIVE_FLUID (385) or CREO_SIMLIVECFD_SET (10138) are not there.
What can I do ?
Mahesh_Sharma
22-Sapphire I
May 10, 2023
Hi GG_10585693,
Thanks.
