Realtime Rendering
dgschaefer
Realtime Rendering
I'm playing with real time rendering in WF4 & WF5. I like it, but the
default settings leave a bit to be desired.
In WF4, the default room has red walls, the stereotypical marble chess
board floor and clouds on the ceiling. Even if I turn off the room in
the rendering setup, it's still there. It really isn't attractive:
WF5 is better, at least I can just render with the floor reflection only
(config option "real_time_rendering_display transparent_floor"). Still,
the light reflections are blue and tan, not exactly natural:
I just want a more realistic rendered model, not a full blown
professional rendering, but no funky colored lights or odd reflections
either. Is that possible? Also, is it possible in WF4 to turn on real
time rendering via config option like it is in WF5?
Doug Schaefer
LinkedIn
0 REPLIES 0
