Our team really wants to be able to turn this text off when working in Assembly mode in Creo Parametric 3:
I have dug through Config.Pro options for hours, and I can't seem to turn this off!
Does anyone know how to remove this text display/overlay from the Assembly Window?
Thank you in advance!
I think you cannot remove unwanted text from graphic window.
From PTC Tecnical Support:
Resolution |
Hello, The theme is quite old, but let me refresh it. As far as the presented solutions are applicable to single screens, what about animation? These subtitles are still visible in animations. Can I turn them off permanently?
Marcin
Did you ever find a fix for this? I have the same issue while making an animation, I would like hide the "simp rep: default REP" text.
Temporary shade doesn't work.
Google led me here!
Hi Stephen,
Thanks for the reply.
The problem with that fix is that the text is over part of my model, which is moving so the background isn't a constant color.
My current "fix" is to shift all the views to the far right of the screen, then crop the left side of the video off in the video editor.
