I have a need to add columns to the simp rep component chooser using "options - column - more"
Does anyone know if there is a way to save the coumn display in the simp rep component chooser?
The "options - save tree" does not seem to work the way I expected it (I expected it to work similar to the "save settings file" in the model tree which creates a tree.cfg file that loads every time Pro/E is started)
It is annoying to have to add the column display to the component chooser everytime one opens Pro/E.
Example of component chooser with three added columns:
There are a great deal of deficiencies in Pro tables as far as I am concerned. I do not know the answer to your question, but if there isn't a good answer that allows the columns to "stick", I'd be happy to add it to this "Idea":
http://communities.ptc.com/ideas/1019
Please let me know.
Bump.
I need a solution to this or else it will be: new_wf5_simp_rep_ui "no"
Jorgen, columns in Simp Rep component chooser are sticky inside session. If you need an ability to have them sticky between sessions, you can file a case with customer support and it will be considered for implementation.
OK, how do I go about filing the case with Custmoer Support?
Go to this link:
http://www.ptc.com/support/index.htm
Click on "Log a new case"
If you do not have an online registered account with PTC support, you will have to register. To do this you will need your customer number, site number and service contract number. Once registered, you will be able to log a case with them through the online form.
Or you can call the PTC support number that your VAR can give you. I find it best to do the online form for internal tracking, etc.
