Hi I need some help. My company just upgraded to Creo. I am now having an issue with preformance. in a drawing everytime i try to edit a note it takes about 35 seconds to open the properties. while doing this creo becomes unresponsive. after it opens it runs fast again until you try to edit a note. then you have another 35 seconds to wait. I am sure it is not the computer because they are new systems we got and are screaming fast... I was wondering if there was a config option not set correctly and creo has to check that each time then continue. thanks for the help.
ok it looks like it was the pro_font_dir \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\Fonts option i had set
appearently it has to think about that everytime becuase I took that out and it works now like it should. I added it because I wanted to specify the font dir so the other creo user and I would both be using the same dir not the ones on our local machines. the fix i found was to just make sure we both have all the fonts we use in the defualt creo font location.
just tried loading creo with it's default options and not my config file. there is no delay in editing text when using that so it must be something with my config.pro file so here it is maybe someone can spot the error.
drawing_setup_file \\LINUX2\shared\ENGINEERING\Pro Engineer\config\creo.dtl
tol_mode nominal
pro_unit_length unit_inch
pro_unit_mass unit_pound
todays_date_note_format %mm/%dd/%yyyy
tolerance_standard ansi
weld_ui_standard ansi
save_display yes
default_dec_places 3
edge_display_quality very_high
smooth_lines yes
shade_quality 14
skip_small_surfaces no
auto_associate_dimensions no
cmdmgr_trail_output yes
cpus_to_use 2
display_axes no
display_axis_tags no
display_coord_sys no
display_coord_sys_tags no
display_plane_tags yes
display_planes no
display_point_tags no
display_points no
dwg_export_format 2010
dxf_block_to_pro_symbol no
dxf_export_format 2010
dxf_out_comments no
dxf_out_sep_dim_w_breaks yes
file_open_default_folder working_directory
general_undo_stack_limit 200
intf2d_in_acad_ignore_3d no
intf2d_in_create_multiline_note no
intf2d_out_acad_mtext no
intf2d_out_acad_text_align as_is
intf2d_out_enhanced_ents spline_and_hatch
intf2d_out_open_log_window no
intf2d_out_pnt_ent yes
intf_in_dwg_pnt_ent no
intf_out_layer none
intf_use_variable_size yes
pdf_use_pentable yes
format_setup_file $PRO_DIRECTORY\text\prodetail.dtl
template_designasm $PRO_DIRECTORY\templates\inlbs_asm_design.asm
template_drawing C:\PTC\templates\b_drawing.drw
template_sheetmetalpart $PRO_DIRECTORY\templates\inlbs_part_sheetmetal.prt
template_solidpart $PRO_DIRECTORY\templates\inlbs_part_solid.prt
pen_table_file \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\TABLE.PNT
pro_format_dir \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\formats
pro_plot_config_dir \\LINUX2\shared\ENGINEERING\Pro Engineer\Config
pro_symbol_dir \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\symbols
pro_texture_library \\LINUX2\shared\ENGINEERING\Pro Engineer\Config
search_path_file \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\SEARCH.PRO
system_colors_file \\LINUX2\shared\ENGINEERING\Pro Engineer\Config\syscol.scl
pro_dtl_setup_dir P:\Pro Engineer\Config
save_drawing_picture_file no
set_trail_single_step yes
suppress_license_loss_dialog yes
tiff_compression g4
trail_delay 3
trail_dir W:\Wayne Trail
trail_dir P:\Pro Engineer\Scot Trail
use_8_plotter_pens yes
vrml_export_resolution high
web_browser_history_days 2
windows_scale 1
use_software_linefonts yes
intf2d_out_cgm_ver 3
sketcher_lock_modified_dims yes
If you believe it to be a config file problem then compare your config side by side with the default config.
Thanks I do know now it must be something with the config because the defualt does not do it. however a comparison between the 2 would not tell me much because almost nothing is the same as the default. I posted mine minus the map keys hopeing someone would know by looking at it what it was. alot of these settings came from my wildfire 3.0 config file I used. I just updated it to use with creo.
Where do you find the original config.pro to compare this too?
Also, how did you set the pro_font_dir if that was your error?
I am having similar situation with my setup.
Dale
Scot,
1.] do not use spaces in folder names (rename Pro Engineer to ProEngineer)
2.] try to map your share to disc letter ... eg. map \\LINUX2\shared to X:
and use pro_font_dir X:\ENGINEERING\ProEngineer\Config\Fonts
Martin Hanak
