Is there any documentation on the syntax for *.PSF and *.PRO file (eg: syntax for comment out line, etc) ?
For PSF file, i always under the assumption that // is used to comment out a line.
However, i notice that if i change the first line // PTC - PSF file: parametric to something like // PTC - PSF file: parametric2, the PSF file will no longer work.
config.pro
parametric.psf
If you need some other information, please provide detailed description of your "goal".
config.pro
parametric.psf
Basically i would just like to include some comment in the PSF file and PRO file (eg: Revision, comment on changes, etc)
From first glance, the default PSF file seems to use // to comment out the line but it seems like it does not really work as comment out since changing the first line of comment [// PTC - PSF file: parametric] will break the file
so you provided information. I am missing your questions.
config.pro
parametric.psf
// USER - PSF
// Add User specific environment or run applications below here
