Syntax for CREO *.PSF and *.PRO file
Is there any documentation on the syntax for *.PSF and *.PRO file (eg: syntax for comment out line, etc) ?
For PSF file, i always under the assumption that // is used to comment out a line.
However, i notice that if i change the first line // PTC - PSF file: parametric to something like // PTC - PSF file: parametric2, the PSF file will no longer work.
