I am using Creo Parametric Release 8.0 and Datecode8.0.6.0
Tangent Lines are not visible when model display is set to wireframe or hidden line display style -
When I view my models in wireframe or hidden, the tangent lines of a cylindrical feature are invisible.
Maybe you need this setting in your config.pro:
display_silhouette_edges yes
Cylinders do not have tangent edges that would show up in Creo as such. Post a picture if the issue. If no tangent lines are visible there could be multiple causes for this.
All lines of a cylinder in wireframe are visible lines not tangent edges.
Here is a hollow cylinder I modeled and here is how it is displayed in various display states.
The default value for that option is yes so someone would have to override that to cause this problem.
@GG_10900066 launch Creo without any environment customizations and then observe what happens with display.
