Tangent lines are not visible in hidden or wireframe display style.
GG_10900066
I am using Creo Parametric Release 8.0 and Datecode8.0.6.0
Tangent Lines are not visible when model display is set to wireframe or hidden line display style -
When I view my models in wireframe or hidden, the tangent lines of a cylindrical feature are invisible.
Maybe you need this setting in your config.pro:
display_silhouette_edges yes
tbraxton
22-Sapphire I
(To:GG_10900066)
Cylinders do not have tangent edges that would show up in Creo as such. Post a picture if the issue. If no tangent lines are visible there could be multiple causes for this.
All lines of a cylinder in wireframe are visible lines not tangent edges.
Involute Development, LLC
Consulting Engineers
GG_10900066
(To:tbraxton)
Here is a hollow cylinder I modeled and here is how it is displayed in various display states.
tbraxton
22-Sapphire I
(To:pausob)
The default value for that option is yes so someone would have to override that to cause this problem.
 @GG_10900066  launch Creo without any environment customizations and then observe what happens with display.
