Curious if anyone has figured out how to toggle between the model tree and the layer tree in Creo Parametric 3.0.
We used the following mapkey in WF3 - WF5. It worked great.
mapkey $F2 @MAPKEY_NAMEDisplay Layer Tree;@MAPKEY_LABELDisplay Layer Tree;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewLyrs.view`;
Creo 3 has changed the commands used to display the layer tree. So far I've been unable to figure out how to make them toggle. I would prefer to not use two separate mapkeys and/or constantly reload config files with alternate versions of the mapkey.
Thanks!
I tried several ways, just editing the mapkeys text but I haven't found a solution too...
Unfortunately, it seems that now you need to recur to something like Autoit or AutoHotKey to achieve this (maybe PTC should include them in Creo installation? ).
I think that this can be done with a batch file too:
1 - A mapkey that calls a batch file, inside the b file a variable is toggled and it writes some text to a trail file.
2 - The mapkey ends reading the trailfile.
That should do it.
Jose.
Second attempt...
I made it just with mapkeys, but still not a elegant solution.
Paste the mapkeys in your config pro and call mapkey "L".
Great!!
I made a mapkey to hide and show specific layers with just one click using the previous method. And is easy to replicate just changing the layer name in the code:
Just to note - the mapkey can reload the alternate config and the alternate config can be a single mapkey. I make them text files, named for what they do, like mapkey_feature_on.txt and mapkey_feature_off.txt. Each one ends with the commands to load the other one.
Yes, I do know that.
Currently I have some working that way.
I´m just testing other methods since that mapkeys tend to stop working sometimes in some computers.
Thanks anyway.
Jose
My best solution until now:
mapkey $F2 %la_hide;
mapkey la_hide ~ Command `ProCmdViewLyrs` 0;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.AddOpt`;\
mapkey(continued) ~ Input `add_opt` `InputOpt` `mapkey`; ~ Update `add_opt` `InputOpt` `mapkey`;\
mapkey(continued) ~ Activate `add_opt` `InputOpt`;~ FocusOut `add_opt` `InputOpt`;\
mapkey(continued) ~ Update `add_opt` `EditPanel` `$F2 %la_show`;\
mapkey(continued) ~ Activate `add_opt` `EditPanel`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
mapkey la_show ~ Command `ProCmdViewLyrs` 1;\
mapkey(continued) ~ Update `add_opt` `EditPanel` `$F2 %la_hide`;\
It works great on my computer, and it's a more simple way.
