I have a problem about exporting my model into .pvz file. However when i attempt to export, they got an error that generates traceback.log file.
You can see some attempts that i tried;
- Updating graphic card driver
- Assigning a parameter which enable_opengl_fbo no
Did you open the case? It is critical issue for us.
Thank you
Community moderators don't open tech support cases.
You need go to https://www.ptc.com/en/support and create a tech support case
OR
If you are thru a VAR, you will need to contact them for tech support.
esupport does not allow me to open case for creo 6.
Does this issue happen on ALL exports to PVZ or just on the specific model you are trying to export? If its only the one specific model, it's possibly a data specific problem that would be difficult. If it is all exports, then it is possibly a setting.
You can try temporarily removing all your config.pro/config.sup, customization files and restart creo and test if that works. If so, then its a local setting you have.
With a little more info, maybe someone on here can help further
How are you trying to export a model to a .pvz file? Those files are ProductViewZipped files and usually generated by Creo View Adaptors now.
File --> Save As -- > Save a copy --> Creo View (.pvz)
