UDF not working because of License problem
AC_9897426
I am using Creo Parametric Release 7.0 and Datecode7.0.3.0
Good Morning dear,
I'm tryng to use de UDF tool, in assemble mode, to customize a project and the follow message shows:
"You have not checked out the license option. Please click "File->Options->Licensing" and choose required option from "Refresh license list".
In the part mode I can acess the tool.
I'm using a locked license.
Here are the errors that I faced
TomU
(To:tbraxton)
Yep.  For reference:
https://www.ptc.com/en/support/article/cs161119
https://www.ptc.com/en/support/article/cs352968
  • When trying to create a UDF in an assembly, getting an error "You have not checked out the license option. Please click "File->Options->Licensing" and choose required option from "Refresh license list"
AC_9897426
(To:AC_9897426)
When I trie it the follow message show.
"There are no floating options currently accessible."
I'm using locked license.
tbraxton
(To:AC_9897426)
You may need a floating license that is advanced assembly extension (AAX) or its equivalent to use the UDF functionality. Can you check on that and report back?
Involute Development, LLC
Consulting Engineers
TomU
(To:tbraxton)
Yep.  For reference:
