Where are the "Help Center" files for download at the PTC.com???
ShandRonnie
6-Contributor
I want to install locally in our network the "Help Center" files that are required prior to installing the Learning Connector.
I know that I can access them remotely, but I want to have them locally to increase access time.
Cannot find the download at the PTC website. Any clues? This is for Wildfire 5.0, M130.
Ronnie Shand
TomU
(To:ShandRonnie)
Looking at my physical disk (for M210), they appear to be bundled with the regular installation as an option. I imagine you would need to download the full installer (for either 32 or 64 bit).
Tom U.
[cid:image001.png@01CFAB47.8BE9B250]
mlocascio
(To:ShandRonnie)
This might require a call to PTC.
TomU
(To:ShandRonnie)
I don't think so. The download should be the same as the disk.
davehaigh
(To:ShandRonnie)
The help files and the learning connector are two different animals. The help center files you download from the same location you download the software.
[cid:image002.jpg@01CFAA73.169D6B10]
The learning connector, in addition to free content, links you to PTC U/Precision LMS. That requires a license from PTC. That license only covers internet access to the content.
If you need to download it to install on a secure network, without internet access. That would require a significant additional fee from PTC.
David Haigh
TomU
(To:ShandRonnie)
The help files are not a separate download for Creo Elements/Pro 5 (Wildfire 5). They are simply an optional component inside the normal install.
[cid:image001.jpg@01CFAB4D.FB33EF30]
