Wildfire 4.0 upgrade to Creo
elau-2
I am new to this company which uses PTC Wildfire 4.0 wanting to upgrade to Creo.
We have a license server and some workstations with Wildfire 4.0 installed on each workstation.
Any upgrade path or documentation that you can share with?
Thanks.
Eric
3 REPLIES 3
BenLoosli
(To:elau-2)
Are you using a PDM system with your Wildfire installation, as that will influence how you do your upgrade?
We use a single installation on a server, so everyone gets upgraded with a single installation.
A Creo upgrade is relatively easy, just install, copy over any customized files, like config.pro, hole files, etc, and go.
Mahesh_Sharma
22-Sapphire I
(To:elau-2)
zzhen
(To:elau-2)
Please refer to Creo Parametric 3.0 Upgrade Resource Center https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS189753
