Win7 ProE crashes on register after setting cache loc
davehaigh
I'm having another Windows 7 issue.
I have an existing startup script for testing new maintenance builds of ProE. Because I don't want to stomp all over my Production cache, I redirect the cache to another folder. All of this worked on XP. Now on Window 7, ProE crashes when I try to register the server.
My startup script looks like this:
set PTC_WF_ROOT="%USERPROFILE%\pro\WF4_test\PDMLink_Cache\PTC\ProENGINEER"
"P:\wf4-m200-64\proeWildfire 4.0\bin\proe.exe"
The windows short cut has the start in dir set to %USERPROFILE%\pro\WF4_test
After crashing, something is still active, because I can't delete the star in directory because Windows says "The action can't be completed because the folder or a file in it is open in another program. Close the folder or file and try again."
If I log out and log back in I can delete the folder. Not sure what process was left hanging by the crash because xtop is not running.
Stumped.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
5 REPLIES 5
I moved the cache pointer to the .psf file a couple of years ago and had no trouble with the move to Win7. The entry would be:
ENV=PTC_WF_ROOT=%USERPROFILE%\pro\WF4_test\PDMLink_Cache\PTC\ProENGINEER
You should not need the quotes. I don't allow spaces in any of my path names to begin with, so I avoid that issue.
The running process is nmsd. Kill that and you should be able to delete the folders.
In Reply to David Haigh:
Stumped.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
David H. Heipel, CAD Systems Administrator
ASRC AEROSPACE CORPORATION
21000 Brookpark Road
MS-ASRC
Cleveland, OH 44135
davehaigh
(To:davehaigh)
PTC just confirmed my problem. The issue is the variable in the path.
SET PTC_WF_ROOT="%USERPROFILE%\wf4cache" <-- doesn't work on Win7
SET PTC_WF_ROOT="C:\Users\haigh1\wf4cache" <-- A static path does work on Win7
It's crasheing because for some as yet unknown reason ProE can't create the folder C:\Users\haigh1\wf4cache when you use the variable.
The thing is it works flawlessly on XP. This may be a Windows 7 specific SPR.
Any insight into this issue would be appreciated.
David Haigh
David,
You might want try setting your variable to a different folder name than 'users.' That's a default Win 7 folder and it might be messing things up. We used 'ptc_users' in lieu of 'users'.
Hope it helps,
Bob Lohbauer
PDM/ PLM Business Administrator
Jacobs Vehicle Systems
22 East Dudley Town Rd.
Bloomfield, CT 06002
davehaigh
(To:davehaigh)
This works:
SET PTC_WF_ROOT=%USERPROFILE%\wf4cache
This doesn't work:
David Haigh
BenLoosli
(To:davehaigh)
If I remember correctly on Vista and Win7, the c:\users folder is a linked folder, it is actually just like XP c:\documents and settings \users.
We also create a top level c:\ptc_users folder on all of our machines, XP and Win7.
Win7 does have some things that need to be adjusted for. I have an install script that sets up the folders for Pro/E and it had to be rewritten for Win7, so I now have one script for XP and one for win7.
Thank you,
Ben H. Loosli
USEC, INC.
