I recently upgraded workstations and have an issue with dragging one Creo window past another leaving remnants on screen. Is there a windows setting to eliminate this? See attached screenshot.
Unchecking the "show windows contents while dragging" is the correct answer. In Windows 7 this is accessed under control panel; System; Performance Information; Adjust visual effects.
I've seen that temporarily but once you let go they'd disappear. The setting that eliminated it, back on XP I think, was unchecking "show window contents while dragging". I have no idea if that's still around in Windows 7 and on.
