annotation help in wildfire 4
ptc-5861883
1-Newbie
need help!!!
i am using Pro-E wildfire 4 and have created a number of annotations by insert>annotation feature>note.
This is fine they are showing in the part fine as they should.
However i need them to show in the assemblies that the part is in, but they are not showing.
any idea how to get them to show. i have gone through the config.pro and cannot find a command to make them show, or an option to get them to show.
any ideas???
1 ACCEPTED SOLUTION
Hi Adam,
Set config option visible_annotations_scope as all and restart Pro/ENGINEER.
4 REPLIES 4
Are they turned off in an assembly layer?
No i have checked the layers and unhidden all lauers to check.
Was my first check though.
Hi Adam,
thanks i had done that but hadnt restarted pro-e, which i have now done and all is showing as it should.
thanks for your help.
