cannot edit the size in sketch
BS_10720905
I am using Creo Parametric Release 8.0 and Datecode8.0.7.0
I cannot edit the size directly in sketch. Initially it worked, but after some time it stopped working. Now the only way I can edit the size in Sketch is by using the ribbon.
Also, I have tried the fixed suggested by article CS352473 but with no luck.
please read https://community.ptc.com/t5/3D-Part-Assembly-Design/Cannot-edit-dimensions-in-sketcher-any-more/m-p/870960#M128823 discussion.
Add following option into config.pro file.
web_browser_homepage about:blank
Martin Hanák
2 REPLIES 2
Martin Hanák
It worked, thank you!
Previously I was editing the wrong config file and the option was not read.
