eror on PE, need help.
ptc-2834811
Hello, can everyone explain me why my PE doesn't work. Then i start program i get message: ""A viewport with the name ""vport1"" does not exist" Can anyone help me to sort it out this problem. my laptop is Asus x50Rseries with ati radeon x1100 graphics Thanks in advance
2 REPLIES 2
Not applicable
(To:ptc-2834811)
Most likely an issue with the graphics driver. Either it hasn't been installed correctly/completely, or it is incompatible. The potential installation issue is discussed at http://www.clausbrod.de/CoCreateModeling/OsdmFaqGraphics#ProperInstallation . If the driver is incompatible, you can try disabling the parts of the driver which implement OpenGL hardware acceleration. This is done by setting an environment variable; details are available at http://www.clausbrod.de/Blog/DefinePrivatePublic20090715NiceAndSlow . Hope this helps, Claus
ptc-2834811
(To:)
Thanks a lot.
